Имееется B6 и шнурок VAG - COM. Считал ошибки, но .... не получается их как-то применить на деле....
Помогите люди добрые пожалуйста.
Вот лог
- Saturday,22,December,2012,18:40:42:32264
VCDS Version: Release 11.11.3
Data version: 20120401
Chassis Type: 3C0
Scan: 01 02 03 08 09 15 16 17 18 19 25 42 44 46 52 53 55 56 62 72
76
VIN: WVWZZZ3CZ6E147375 Mileage: 125410km/77926miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: Malfunction 0010
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: Malfunction 0010
18-Aux. Heat -- Status: Malfunction 0010
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: Malfunction 0010
46-Central Conv. -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
55-Xenon Range -- Status: OK 0000
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: Cannot be reached 1100
72-Door, Rear Right -- Status: Cannot be reached 1100
76-Park Assist -- Status: Malfunction 0010
Address 01: Engine Labels: 03G-906-018-BKP.clb
Part No SW: 03G 906 018 CK HW: 03G 906 018 CK
Component: R4 2.0l PPD1.5 G 9629
Revision: --H15--- Serial number: VWZCZ000000000
Coding: 0000078
Shop #: WSC 00131 935 56600
VCID: 70E5CE1963B8329
2 Faults Found:
17671 - PD Unit Injector: Cylinder 2 (N241)
P1263 - 006 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00100001
Fault Priority: 0
Fault Frequency: 7
Reset counter: 38
Mileage: 125305 km
Time Indication: 0
Date: 2012.12.17
Time: 13:34:28
Freeze Frame:
RPM: 704 /min
Text: 88 Nm
Speed: 46.0 km/h
Load: 53.3 %
Text: 5.375 uF
Time: 0.00 ms
Text: 0.00 mJ
17672 - PD Unit Injector: Cylinder 2 (N241)
P1264 - 006 - Regulation Range Exceeded - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 7
Reset counter: 38
Mileage: 125307 km
Time Indication: 0
Date: 2012.12.19
Time: 13:29:42
Freeze Frame:
RPM: 768 /min
Text: 56 Nm
Speed: 0.0 km/h
Load: 76.9 %
Text: 5.125 uF
Text: 12.50 mJ
Text: 6 mJ
Raw, Form. N/A: 000 000 000
Readiness: N/A
Address 02: Auto Trans Labels: 02E-300-0xx.lbl
Part No SW: 02E 300 043 M HW: 02E 927 770 AE
Component: GSG DSG 081 1304
Revision: 04508010 Serial number: 00000704190635
Coding: 0000020
VCID: 1E39C0A1C9ACF49
No fault code found.
Address 03: ABS Brakes Labels: 3C0-614-095-C2.clb
Part No SW: 3C0 614 095 Q HW: 3C0 614 095 Q
Component: ESP 440 C2 H015 0003
Revision: H015 Serial number: 0658477269
Coding: 0015653
Shop #: WSC 00137 935 94601
VCID: 30650E19A338729
1 Fault Found:
00778 - Steering Angle Sensor (G85)
005 - No or Incorrect Basic Setting / Adaptation
Address 08: Auto HVAC Labels: 3C0-907-044.lbl
Part No SW: 3C0 907 044 AD HW: 3C0 907 044 AD
Component: ClimatronicPQ46 050 0404
Revision: 00050005 Serial number: 00000000000000
Shop #: WSC 00000 000 00000
VCID: 63CFB155A24E991
3 Faults Found:
01316 - ABS Control Module
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 5
Fault Frequency: 14
Reset counter: 94
Mileage: 125299 km
Time Indication: 0
Date: 2012.12.16
Time: 21:55:34
00819 - High Pressure Sensor (G65)
009 - Open or Short to Ground - Intermittent
Freeze Frame:
Fault Status: 00111001
Fault Priority: 2
Fault Frequency: 15
Reset counter: 94
Mileage: 125299 km
Time Indication: 0
Date: 2012.12.16
Time: 21:55:40
00457 - Control Module for Network (J519)
Freeze Frame:
Fault Priority: 5
Fault Frequency: 4
Reset counter: 94
Mileage: 125307 km
Time Indication: 0
Date: 2012.12.19
Time: 13:30:06
Address 09: Cent. Elect. Labels: 3C0-937-049-23-H.lbl
Component: Bordnetz-SG H37 1301
Revision: 00H37000 Serial number: 00000002183958
Coding: F6828F0700041A00000A00000F000000000F5D435C0000
Shop #: WSC 05311 123 12345
VCID: 32610411AD34409
Subsystem 1 - Part No: 3C1 955 119 Labels: 1KX-955-119.CLB
Component: Wischer VW461 012 0503
Coding: 00065493
Shop #: WSC 05311
Subsystem 2 - Part No: 1K0 955 559 T Labels: 1K0-955-559-AF.CLB
Component: RegenLichtSens 011 1110
Coding: 00208933
Shop #: WSC 05311
3 Faults Found:
01333 - Door Control Module; Rear Left (J388)
Freeze Frame:
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 53
Reset counter: 54
Mileage: 125299 km
Time Indication: 0
Date: 2012.12.16
Time: 21:52:00
Freeze Frame:
ON
Voltage: 14.25 V
ON
ON
OFF
OFF
OFF
01334 - Door Control Module; Rear Right (J389)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 53
Reset counter: 54
Mileage: 125299 km
Time Indication: 0
Date: 2012.12.16
Time: 21:52:00
Freeze Frame:
ON
Voltage: 14.25 V
ON
ON
OFF
OFF
OFF
00446 - Function Limitation due to Under-Voltage
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 4
Fault Frequency: 1
Reset counter: 94
Mileage: 125417 km
Time Indication: 0
Date: 2012.12.22
Time: 00:03:00
Freeze Frame:
OFF
Voltage: 12.20 V
OFF
ON
OFF
OFF
OFF
Address 15: Airbags Labels: 3C0-909-605.lbl
Part No SW: 3C0 909 605 J HW: 3C0 909 605 J
Component: 04 AIRBAG VW8 029 2521
Revision: 09029000 Serial number: 003A2PR3N48J
Coding: 0012340
Shop #: WSC 05311 000 00000
VCID: 2D5B176DB40A1F1
Address 16: Steering wheel Labels: 3C0-953-549-SW20.lbl
Part No SW: 3C0 953 549 E HW: 3C0 953 549 E
Component: J0527 0015
Revision: 00005000 Serial number: 3C5953507P
Coding: 0001111
VCID: 2E591061B90C649
Part No: XXXXXXXXXXX
Component: E0221 007 0050
Address 17: Instruments Labels: 3C0-920-xxx-17.lbl
Part No SW: 3C0 920 870 Q HW: 3C0 920 870 Q
Component: KOMBIINSTRUMENT VD1 4240
Revision: X0033000 Serial number: 00000000000000
Coding: 0007105
Shop #: WSC 00011 888 96745
VCID: 31630B1DA8327B1
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 8
Reset counter: 94
Mileage: 125303 km
Time Indication: 0
Date: 2012.12.17
Time: 12:52:52
Address 18: Aux. Heat Labels: None
Part No: 1K0 815 071 P
Component: Zuheizer 031 1312
Revision: A Serial number: 09010046
Coding: 0000011
Shop #: WSC 00132 935 93954
4 Faults Found:
01444 - Under-Voltage Shut-Off (Automatic)
000 - - - Intermittent
Freeze Frame:
01407 - Flame Extinguished
Freeze Frame:
Fault Status: 00100000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 94
Mileage: 125416 km
Time Indication: 0
Date: 2012.12.22
Time: 09:16:21
Freeze Frame:
Start
Temperature: -16.0°C
Temperature: -48.0°C
01406 - No Flame
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 54
Mileage: 125416 km
Time Indication: 0
Date: 2012.12.22
Time: 09:35:23
Freeze Frame:
Start
Temperature: -21.0°C
Temperature: -24.0°C
01409 - Repeated Flame-Out
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 54
Mileage: 125416 km
Time Indication: 0
Date: 2012.12.22
Time: 09:36:13
Freeze Frame:
Malfunction
Address 19: CAN Gateway Labels: 3C0-907-530.lbl
Component: Gateway 007 0040
Revision: 00007000 Serial number: 0700C05C060CB4
Coding: 7FFD1C04CA1002
VCID: 2143FB5DF8D2CB1
2 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 36
Mileage: 125299 km
Time Indication: 0
Date: 2012.12.16
Time: 21:53:27
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 36
Mileage: 125299 km
Time Indication: 0
Date: 2012.12.16
Time: 21:53:27
Address 25: Immobilizer Labels: 3C0-959-433-25.clb
Part No SW: 3C0 959 433 M HW: 3C0 959 433 M
Component: IMMO 042 0383
Revision: 00042000 Serial number: VWZCZ000000000
VCID: 346D020957204E9
Part No: 3C0 905 861 G
Component: ELV 027 0380
3C0905861G ELV 027 0380
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN2.lbl
Part No: 1K0 959 701 K
Component: Tuer-SG 024 2365
Coding: 0000245
VCID: 36693801415C5C9
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K1 909 144 K
Component: EPS_ZFLS Kl.5 D06 1701
VCID: 336F0115522E491
1 Fault Found:
000 - -
Address 46: Central Conv. Labels: 3C0-959-433-46.clb
Component: A_ KSG PQ46 ELV 042 0472
Coding: 009008084103087F3F048F05C0084F0B103C80
Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H03 1301
Component: NGS n.mounted
Component: IRUE n.mounted
2 Faults Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 3
Reset counter: 54
Mileage: 125299 km
Time Indication: 0
Date: 2012.12.16
Time: 21:53:56
Freeze Frame:
Fault Priority: 4
Fault Frequency: 3
Reset counter: 54
Mileage: 125299 km
Time Indication: 0
Date: 2012.12.16
Time: 21:53:56
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN2.lbl
Part No: 1K0 959 702 K
Coding: 0000244
VCID: 377735054656A51
Address 53: Parking Brake Labels: 3C0-907-801-53.clb
Component: EPB VC8HC001 013 0001
Revision: 013
Coding: 0000012
Address 55: Xenon Range Labels: 5M0-907-357-V1.lbl
Part No SW: 5M0 907 357 HW: 5M0 907 357
Component: AFS-Steuergeraet X016
Revision: H09 Serial number:
Coding: 0000001
VCID: F1E34B1DE8B2BB1
Subsystem 1 - Part No: 7L6 941 329
Component: AFS-Lst.-Modul l X017
Coding: 00000035
Subsystem 2 - Part No: 7L6 941 330
Component: AFS-Lst.-Modul r X017
Coding: 00000035
Address 56: Radio Labels: 1K0-035-1xx-56.lbl
Part No: 1K0 035 186 P
Component: Radio GR0 015 0019
Revision: 0001503S Serial number: VWZ2Z2E3155400
Coding: 0040400
Address 62: Door, Rear Left
Cannot be reached
Address 72: Door, Rear Right
Cannot be reached
Address 76: Park Assist Labels: 3C0-919-283.lbl
Part No SW: 3C0 919 283 B HW: 3C0 919 283 B
Component: Parkhilfe 8-Kan 004 0011
Revision: 00004000 Serial number: 82930533703448
Coding: 0001014
VCID: 2855E6799BE83A9
1 Fault Found:
01628 - Sensor for Parking-Aid; Front Mid-Left (G254)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 37
Mileage: 125303 km
Time Indication: 0
Date: 2012.12.16
Time: 22:18:57
End ---------------------------------------------------------------------
