Ошибка 03252 - Engine Control Module for Hybrid Drive
Сообщение 234dimon » 11 мар 2014, 15:33
Погите по ошибке 44 блок. 03252
2008г. 1.6 BSE, MFA плюс
Вот полный скан
Chassis Type: 3C0
Scan: 01 03 08 09 15 16 17 19 25 37 42 44
46 52 53 56
VIN: XW8ZZZ3CZ9G001037 Mileage:
97010km/60279miles
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: Malfunction
0010
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
37-Navigation -- Status: Malfunction 0010
42-Door Elect, Driver -- Status:
Malfunction 0010
44-Steering Assist -- Status: Malfunction
0010
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status:
Malfunction 0010
53-Parking Brake -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
Address 01: Engine Labels: 06A-906-033-
BGU.lbl
Part No: 06A 906 033 EF
Component: SIMOS72 1.6l 2VG 1045
Revision: --H04--- Serial number:
VWZCZ000000000
Coding: 0004071
Shop #: WSC 00105 935 21670
VCID: 67D9BFAF2FFD
No fault code found.
Readiness: 0000 0000
Address 03: ABS Brakes Labels:
3C0-614-109-C4.lbl
Part No SW: 3C0 614 109 N HW: 3C0 614
109 N
Component: J104 C4 440 V1 0011
Revision: --025--- Serial number:
00000785663955
Coding: 0004415
Shop #: WSC 00028 028 00001
VCID: 295DF997F969
1 Fault Found:
00778 - Steering Angle Sensor (G85)
005 - No or Incorrect Basic Setting /
Adaptation
Address 08: Auto HVAC Labels:
3C0-907-044.lbl
Part No SW: 3C0 907 044 DC HW: 3C0 907
044 DC
Component: ClimatronicPQ46 132 0811
Revision: 00132023 Serial number:
00000000000000
Shop #: WSC 00000 000 00000
VCID: 65C5B5A7D5F1
Address 09: Cent. Elect. Labels:
3C0-937-049-30-H.lbl
Part No SW: 3C8 937 049 H HW: 3C8 937
049 H
Component: Bordnetz-SG H54 2602
Revision: 00H54000 Serial number:
00000005816252
Coding:
E4848F0700041A000800003232000000000D3A4F5C001100000000000000
VCID: 366722EB38D7
Part No: 3C1 955 419 A
Component: Wischer 110408 003 0205
Coding: 00114581
Shop #: WSC 00028
Part No: 1K0 955 559 AH
Component: RLS 180113 054 0403
Coding: 02052301
Shop #: WSC 00028
Address 15: Airbags Labels:
5N0-959-655.lbl
Part No SW: 5N0 959 655 A HW: 5N0 959
655 A
Component: J234__005 VW10 HI 1815
Revision: 19013000 Serial number:
0039DPA5JYC1
Coding: 0012341
VCID: 3B7133DF03F5
Address 16: Steering wheel Labels:
3C0-953-549-SW20.lbl
Part No SW: 3C0 953 549 AC HW: 3C0 953
549 AC
Component: J0527 0020
Revision: 00026000 Serial number:
3C9953507AR
Coding: 0000113
Shop #: WSC 05311 000 00000
VCID: 6DD5CD870D01
Part No: XXXXXXXXXXX
Component: E0221 002 0010
1 Fault Found:
00888 - Wiper Switch for Intermittent
Operation (E22)
014 - Defective
Address 17: Instruments Labels: 3C0-920-
xxx-17.lbl
Part No SW: 3C0 920 870 T HW: 3C0 920
870 T
Component: KOMBIINSTRUMENT VD1 1614
Revision: V0007000 Serial number:
00000000000000
Coding: 0007105
Shop #: WSC 00999 444 64523
VCID: 346318E32EAB
Address 19: CAN Gateway Labels:
3C0-907-530.lbl
Part No SW: 3C0 907 530 H HW: 3C0 907
951
Component: J533__Gateway H13 0142
Revision: H13 Serial number:
2600P085200102
Coding: F9801F064002021002
VCID: 2647F2ABE877
Address 25: Immobilizer Labels:
3C0-959-433-25.clb
Part No SW: 3C0 959 433 AB HW: 3C0 959
433 AB
Component: IMMO 043 0383
Revision: 00043000 Serial number:
VWZCZ000000000
Shop #: WSC 00121 935 91130
VCID: 6ADFC69B3CEF
Part No: 3C0 905 861 J
Component: ELV 029 0380
3C0905861J ELV 029 0380
Address 37: Navigation (J0506) Labels:
1T0-035-680.clb
Part No SW: 1T0 035 680 D HW: 1T0 035
680 B
Component: RNS-MID H03 4020
Revision: AB001001 Serial number:
Coding: 000104000400001E0000
Shop #: WSC 00020 790 00000
ASAM Dataset:
VCID: 2F69178FC78D
1 Fault Found:
00856 - Radio Antenna
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00101011
Fault Priority: 5
Fault Frequency: 27
Reset counter: 43
Mileage: 96624 km
Time Indication: 0
Date: 2014.03.03
Time: 05:20:12
Address 42: Door Elect, Driver Labels:
1K0-959-701-MIN3.lbl
Part No SW: 1K0 959 701 AC HW: 1K0 959
793 N
Component: J386 TUER-SG FT 1517
Revision: 72009005 Serial number:
00000537488527
Coding: 0000117
VCID: 6FE9D78F070D
1 Fault Found:
00466 - Control Module for Steering
Column Electronics (J527)
004 - No Signal/Communication -
Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 4
Fault Frequency: 2
Reset counter: 43
Mileage: 96947 km
Time Indication: 0
Date: 2014.03.05
Time: 16:58:05
Address 44: Steering Assist Labels:
1Kx-909-14x-44.clb
Part No: 1K1 909 144 M
Component: EPS_ZFLS Kl.132 H08 1901
Shop #: WSC 00121 935 186131
VCID: 356525E725D1
3 Faults Found:
Drive
004 - No Signal/Communication - MIL ON
Freeze Frame:
Mileage: 96940 km
Temperature: 10.0°C
Voltage: 14.30 V
Voltage: 14.10 V
02546 - Steering Limit Stop
Adaptation
Freeze Frame:
Mileage: 96940 km
Temperature: 10.0°C
Voltage: 14.30 V
Voltage: 14.10 V
Adaptation
Freeze Frame:
Address 46: Central Conv. Labels:
3C0-959-433-46.clb
433 AB
Component: KSG PQ46 ELV 043 0472
VWZCZ000000000
Coding:
00910A0801864E7637041C1D600ECB0E603C01
VCID: 6ADFC69B3CEF
Component: Sounder n.mounted
Component: NGS n.mounted
Component: IRUE n.mounted
Address 52: Door Elect, Pass. Labels:
1K0-959-702-MIN3.lbl
Part No SW: 1K0 959 702 AC HW: 1K0 959
792 N
Component: J387 TUER-SG BT 1517
00000093288526
Coding: 0000117
VCID: 70EBD4F31A33
1 Fault Found:
Intermittent
Freeze Frame:
Fault Priority: 4
Fault Frequency: 2
Reset counter: 43
Mileage: 96947 km
Time Indication: 0
Date: 2014.03.05
Time: 16:58:05
Address 53: Parking Brake Labels:
5N0-907-801.lbl
Part No SW: 3C8 907 801 A HW: 3C8 907
801 A
Component: J540 EPB3 VW-10498 0003
Revision: 008 Serial number:
00000000017180
Coding: 0000057
VCID: 285BFC93E263
Address 56: Radio (J0506) Labels:
1T0-035-680.clb
680 B
ASAM Dataset:
VCID: 2F69178FC78D
1 Fault Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 27
Reset counter: 43
Mileage: 96624 km
Time Indication: 0
Date: 2014.03.03
Time: 05:20:12
End
Последний раз редактировалось 234dimon 13 мар 2014, 19:17, всего редактировалось 1 раз.
234dimon
Re: Ошибки в 44 блоке
Сообщение Alemania » 11 мар 2014, 16:01
Когда появилась ошибка ?
С кодировками игрались ?
С адаптациями в 44 блоке ?
Или ничего не трогал...оно само... ?
Сообщение 234dimon » 11 мар 2014, 17:58
поменял подрулевой блок и поставил мультируль 8 кнопочный...... вроде больше ничего не делал, ставлю старый подрулевой блок - таже ерунда... ошибку сбрасывал,но.... опять появляется...
234dimon
Сообщение Alemania » 11 мар 2014, 18:41
где то включена функция которая отсутствует в этой машине...
Сообщение 234dimon » 11 мар 2014, 18:47
это понятно что включено то, чего нет, вот и пытаюсь победить, но пока на ум ничего не приходит..... может у кого то такое было ?!
234dimon
Сообщение 234dimon » 11 мар 2014, 20:13
Большое спасибо за ссылку... я так понял что у предыдущего хозяина блока был активирован park pilot, а у меня его нет.
Значит в 7 канале адаптации надо поставить -0
Домой с работы приеду попробую. О результатах отпишусь...
234dimon
Сообщение Alemania » 11 мар 2014, 20:17
234dimon писал(а):Большое спасибо за ссылку... я так понял что у предыдущего хозяина блока был активирован park pilot, а у меня его нет.
не все ссылки прочитал....такая реакция возникает у людей вообще на какие то детские изменения...Я бы начал все с нуля. Вернуть как было со всеми кодировками, вернуть все блоки и рули взад...проверить установленное оборудование в 19 блоке, избавиться от ошибки, а потом уж начинать пошагово апгрейд.
Насколько я понял из прочитанного..решения однозначного ни у кого нет...у всех все по разному, только ошибка одна и та же.
Ведь 44 блок не менялся же ???
Сообщение 234dimon » 11 мар 2014, 20:33
может значение меняется автоматом т.к в 16 блоке сначала была ошибка, что нет сигнала с блока параллельной парковки..... в 16 блоке каналы адаптации я подправил, а в 44 и не догадался посмотреть !!!!!!
234dimon
Сообщение 234dimon » 12 мар 2014, 21:41
Получилось победить ошибку !!!! Как и предпологал в 7 канале адаптации стояла 1, поменял на 0 и ошибка пропала !!!!
Теперь осталось адаптировать датчик G85...
Тему можно закрывать ... Большое спасибочки за помощь !!!!
234dimon
Сообщение Alemania » 13 мар 2014, 04:58
234dimon писал(а):Получилось победить ошибку !!!! Как и предпологал в 7 канале адаптации стояла 1, поменял на 0 и ошибка пропала !!!!
Тему переименуй по номеру ошибки если не трудно...кому нибудь да поможет.
Вернуться в Ошибки
