Двигатель пошел в разнос
Re: Двигатель пошел в разнос
Сообщение hanac1985 » 21 мар 2013, 00:15
смотри.
1,0 /min,,0.0 mg/str,,0.0°KW,,2.0°C,,
2,0 /min,,0.0 %,,00001000,,2.0°C,,
3,0 /min,,0.0 mg/str,,0.0 mg/str,,0.0 %,,
4,0 /min,,120.0 °BTDC,,0.0°KW,,2.97°,, 120.0 °BTDC момент впрыска?????
5,0 /min,,170.0 Nm,,3.0,,2.0°C,,
6,0.0 km/h,,00101000,,0.0 %,,10000001,,
7,3.0°C,, ,,3.0°C,,2.0°C,,
8,0 /min,,0.0 Nm,,1024.0 Nm,,1024.0 Nm,,
9,0 /min,,-977.5 Nm,,1024.0 Nm,,1024.0 Nm,, давление???
10,0.0 mg/str,,990.7 mbar,,999.1 mbar,,0.0 %,,
11,0 /min,,999.1 mbar,,999.1 mbar,,20.0 %,,
12,01010000,,2.00 s,,12.198 V,,2.0°C,,
13,0.00 mg/str,,0.00 mg/str,,0.00 mg/str,,0.00 mg/str,,
15,0 /min,,0.0 Nm,,0.00 l/h,,0.0 Nm,,
16,12.2 %,,11011100,,0,,12.198 V,,
17,00000000,,00000110,,10000000,,10000000,,
18,2.0,,2.0,,2.0,,2.0,,
19,0.00 V,,0.00 V,,0.00 V,,0.00 V,,
20,0 /min,,0.0 Nm,,1024.0 Nm,,0.0 Nm,, ???????
21,00000000,,01000000,,00000000,,00000100,,
22,6,,1.0,,0.0,,0.0,,
23,0.00 ms,,0.00 ms,,0.00 ms,,0.00 ms,,
25,0 /min,, ,,Выкл. двиг.,,192.0,,
26, 003522E2H,,
27, ,, ,,0.0 km/h,,210.0 km/h,,
28,0.742 V,,0.371 V,,00001000,,0.0 %,,
29,0.0°C,,29.0 mm,,0 km,,0 km,,
41,96.0 %,,0.0 %,,0.8 %,,-10.0 %,,
42,0.893 V,,00000000,,96.0 %,,0.8 %,,
44,0 /min,,0.0 mg/str,,1.0,, ,,
45, ,,0.0 mbar,,0.00 g/s,,999.1 mbar,,
46,96.0 %,,96.0 %,,95.8 %,,-9.2 %,,
47,0.507 V,,4.628 V,,-9.6 %,,95.8 %,,
51,0 /min,,0 /min,,3.0,,01000000,,
52,10110000,, ,, ,, ,,
53,0.000 Nm,,0.000 Nm,,0.000 Nm,,0.000 Nm,,
54,4.62,,4.62,,4.62,,4.62,,
55, ,, ,,00000000,,00000000,,
56,00000000,,00000000,, ,, ,,
57,B0C7ABDDH BB88D7A6H 16147278H 84F224DEH ,,
62,2.0°C,,1.0°C,,0.7°C,,3.0°C,,
63,2.00 bar,,0.0 Nm,,0.0 %,,0.0,,
64,2.0°C,,1.0°C,,9.8 %,, ,,
80,SJ8-FST 25.08.07 --H45--- 0415 1304 ,,
81,WVWZZZ3CZ8E098462 VWZCZ000000000 <> ,,
82,0000000000000 <> 078 01JN <> <> ,,
86,00000010,,00001000,,01101011,, ,,
89,00000000,,00000110,,10000000,,10000000,,
90,0 /min,,0.0 mg/str,,0.0 mg/str,,00000000,,
91,0.0 %,,0.0 %,,0.0 mg/str,,0.0 %,,
93,00000000,,1.00,,0.00 g/s,,0.00 g/s,,
110,выкл,, ,, ,, ,,
111, ,, ,, ,,12.312 V,,
115,3.00 m/s^2,,0.0 Nm,,0.0 Nm,,0.0 Nm,,
116,00001100,,0.0,,00000001,,0.0,,
117,4.0,,99.0,,3.00 m/s^2,,0.00 m/s^2,,
118,0.0 %,, ,, ,, ,,
125, ,,ABS 1,,Приборы 1,,Airbag 1,,
126,Клим. уст. 1,, ,, ,, ,,
127, ,, ,,Эл.з.зажиг. 1,,Рул.колесо 1,,
128,Шлюз 1,, ,, ,,Стоян.торм. 1,,
131,0.0,,0.0 mg/str,, ,,2.0°C,,
133,0 /min,,0.0 mg/str,,999.1 mbar,,0.0,,
134,12.2 %,,12.312 V,, ,, ,,
140, ,, ,,00000110,,10000000,,
150,0 /min,,170.0 Nm,,3.0,,2.0°C,,
151,0 /min,,0.0 Nm,,1024.0 Nm,,1024.0 Nm,,
152,0 /min,,0.0 Nm,,0.0 Nm,,12.2 %,,
154,0 /min,,0.0 mg/str,,0.0 mg/str,,0.0 %,,
155,0 /min,,961 /min,,00001000,,0.0 %,,
156,0 /min,,210.0 km/h,,0.0 km/h,,0.0 Nm,,
157,0 /min,,2.00 s,,2.0°C,,01010000,,
158,0 /min,,0.0 Nm,,0.0 Nm,,0.0,,
161,0 /min,,0,,0.0 l,,0 km,,
165,0 /min,,0.8 %,,0.0 mg/str,,0.0 %,,
166,0 /min,, ,,999.1 mbar,,20.0 %,,
167,0 /min,, ,,3.0°C,,2.0°C,,
168, ,,0.742 V,,0.371 V,,0.0 %,,
169,10110000,, ,, ,, ,,
194,0 /min,,0.0 mg/str,,0.0 km/h,,2.0°C,,
213,0 /min,,0.0 %,,0.0 km/h,,0.0,,
225, ,,0.0,,0.0,,0.0,,
226,0.0,, ,, ,, ,,
227, ,, ,,0.0,,0.0,,
228,0.0,, ,, ,,0.0,,
235,0 /min,,0.8 %,,0.0 mg/str,,0.0 %,,
236,0 /min,, ,,2.00 bar,,0.0,,
237,0 /min,, ,,999.1 mbar,,20.0 %,,
238,0 /min,, ,,12.2 %,,12.198 V,,
239,0 /min,, ,,0.0 mg/str,,12.198 V,,
240,0 /min,, ,,0.0 mg/str,,96.0 %,,
241,0 /min,, ,,2.0°C,,12.312 V,,
242,0 /min,, ,,2.0°C,,12.312 V,,
243,0 /min,, ,,01010000,,12.198 V,,
244,0 /min,, ,,2.0°C,,9.8 %,,
245,0 /min,, ,,0.0 mg/str,,12.198 V,,
246,0 /min,, ,,2.0°C,,12.312 V,,
247,0 /min,, ,,11011100,,12.198 V,,
248,0 /min,, ,,2.0°C,,12.198 V,,
252,Airbag 1,, ,, ,,Клим. уст. 1,,
Vw Passat B6 2.0 TDI bkp, 2007 г., на ручке - продан
Honda Civic 5d 1.8 2008 г., робот
hanac1985
Откуда: Тишково, Лобня, Москва, Железнодорожный, Саратов......
Сообщение hanac1985 » 21 мар 2013, 00:19
тут быстрее и проще найти неполадки.. ну или для себя уяснить какие нибудь данные...
А так приходиться отдельно по три группы на страничке открывать..
И просто в данной ситуации меня интересует на момент когда двигатель не заведен. что датчики выдают.
к примеру 4 и 9 группа
hanac1985
Сообщение hanac1985 » 21 мар 2013, 00:22
адаптация, тех или иных функции установленных в авто и забитых в память ЭБУ.
В памяти ЭБУ зашиты заводские установки, Но некоторые возможности не адаптированны
hanac1985
Сообщение slavik049 » 21 мар 2013, 11:57
hanac1985 писал(а):адаптация, тех или иных функции установленных в авто и забитых в память ЭБУ.
ну и что нашел по этому скану в своем авто ?
Сообщение hanac1985 » 21 мар 2013, 17:01
на данный момент не могу ответить тебе на этот вопрос... я просто больше озадачен находкой проблеммы незавода.
А этот список, это весь список показателей датчиков(настроек) блока 1 (двигателя).
тоже самое что ты заходишь в двигатель, выбираешь там измерение, и в трех колонках выставляеш группы и смотришь их показатели по четырем колонкам сохроняешь их в лог фаил . Ну или выбирая другой тип измерений, выбираешь из списка 12 тех, которые тебя интересуют и сохроняешь их в лог фаил.
так просто проще и сразу все видно.
hanac1985
Сообщение hanac1985 » 27 мар 2013, 16:13
Собрал.. Завелась с трудом... И заглоха. из выхлоной серый дым. может что то забыл. Хм...
hanac1985
Сообщение slavik049 » 27 мар 2013, 18:41
hanac1985 писал(а):Собрал.. Завелась с трудом... И заглоха. из выхлоной серый дым. может что то забыл. Хм...
Привет ;) пробуй открыть горловину масла и пробуй завестись .Если от туда не повалит дым ....значит все хорошо !Остальное ерунда.
Сообщение hanac1985 » 27 мар 2013, 22:36
так а если повалит?
если завести со снятой крышкой, ну кроме разбрызгивания масла... и что если система впуска ОГ не герметична не создает давление
hanac1985
Сообщение slavik049 » 27 мар 2013, 22:41
Все отбрось ....масло не разбрызгает (проверял ) попробуй завести .
Лиж бы не повалил!
Сообщение hanac1985 » 27 мар 2013, 23:34
да не должен. так то я бы увидел.у меня с клапана вкг трубка снята была. хотя я тут заморочился и начал сценарий процесса неисправности проводить и пришел к ужасающим выводам....
hanac1985
Сообщение slavik049 » 27 мар 2013, 23:47
hanac1985 писал(а):да не должен. так то я бы увидел.у меня с клапана вкг трубка снята была. хотя я тут заморочился и начал сценарий процесса неисправности проводить и пришел к ужасающим выводам....
КАКИМ? :(
Сообщение hanac1985 » 28 мар 2013, 00:00
завтра напишу
hanac1985
Сообщение hanac1985 » 31 мар 2013, 15:58
разболталось посадочное место насос форсунки.... Что делать?
hanac1985
Сообщение slavik049 » 31 мар 2013, 18:13
hanac1985 писал(а):разболталось посадочное место насос форсунки.... Что делать?
Привет :( чем больше там капаешь тем больше расстраиваешься ??
Вот что написано по твоей проблеме .....прокрути в низ .... http://www.golf-v.ru/forum/41---/8176-----.html
Ну второй вариант заменить кольца и болты крепления.... какой износ то ?
Сообщение hanac1985 » 31 мар 2013, 19:59
там писец... надо голову снимать. смотреть что с поршневой.
когда думаешь что хуже не предумаешь, почему то получается придумать.
hanac1985
Сообщение hanac1985 » 31 мар 2013, 20:24
там не то что разболтались... там он разбит! 7мм на см и глубиной в 2 мм.
hanac1985
Сообщение slavik049 » 31 мар 2013, 20:26
hanac1985 писал(а):там не то что разболтались... там он разбит! 7мм на см и глубиной в 2 мм.
А голову снял?
Сообщение hanac1985 » 31 мар 2013, 21:42
Пока нет... Но в любом случае надо снимать. Устал уже расстраиваться. Хотя если представить сколько эти работы в сервисе стоят...
hanac1985
Сообщение hanac1985 » 10 апр 2013, 00:41
посадочное место для насос форсунки 2-го цилиндра разбило...
Последний раз редактировалось hanac1985 10 апр 2013, 08:09, всего редактировалось 2 раз(а).
hanac1985
Сообщение hanac1985 » 10 апр 2013, 00:44
вот такая беда...
Последний раз редактировалось hanac1985 10 апр 2013, 08:11, всего редактировалось 1 раз.
hanac1985
Сообщение hanac1985 » 10 апр 2013, 00:46
отверстие, *дырка* )))) понять не могу вот только должна ли она быть...
Последний раз редактировалось hanac1985 10 апр 2013, 08:22, всего редактировалось 1 раз.
hanac1985
Сообщение hanac1985 » 10 апр 2013, 00:48
hanac1985
Сообщение hanac1985 » 10 апр 2013, 00:50
hanac1985
Сообщение hanac1985 » 10 апр 2013, 07:55
hanac1985
Сообщение hanac1985 » 12 апр 2013, 23:41
снял гбц... мне вот интересно два цилиндра 1 и 4 вверху а 2 и 3 внизу, по идеи так не должно быть....????! фотки кину потом
hanac1985
