Помогите с ошибками BVY
Сообщение komsa64 » 30 апр 2015, 00:38
Saturday,11,April,2015,20:19:41:62939
VCDS Version: Release 12.12.0 (x64)
Address 01: Engine Labels: Redir Fail!
Control Module Part Number: 06F 997 058 R HW: 06F 906 056 EK
Component and/or Version: MED9.5.10 G00 2770
Software Coding: 0000075
Work Shop Code: WSC 00102 935 60450
VCID: 4487AA9B076E043EF0B-8011
4 Faults Found:
004195 - Fuel Pressure Regulation
P1063 - 002 - Control Range Not Reached - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 91062 km
Time Indication: 0
Date: 2000.00.00
Time: 16:02:20
Freeze Frame:
RPM: 640 /min
Load: 85.5 %
Speed: 0.0 km/h
Temperature: 48.0°C
005120 - EGR Valve (N18)
P1400 - 002 - Electrical Malfunction - MIL ON
Freeze Frame:
Fault Status: 11100010
Fault Priority: 0
Fault Frequency: 3
Reset counter: 255
Mileage: 92110 km
Time Indication: 0
Date: 2000.00.00
Time: 13:13:51
Freeze Frame:
RPM: 1440 /min
Load: 44.3 %
Speed: 47.0 km/h
Temperature: 66.0°C
000768 - Random/Multiple Cylinder Misfire Detected
P0300 - 001 - - Intermittent
Freeze Frame:
Fault Status: 00100001
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 92151 km
Time Indication: 0
Date: 2000.00.00
Time: 11:12:42
Freeze Frame:
RPM: 720 /min
Load: 29.8 %
Speed: 0.0 km/h
Temperature: 49.0°C
000771 - Cylinder 3
P0303 - 001 - Misfire Detected - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 92151 km
Time Indication: 0
Date: 2000.00.00
Time: 11:12:42
Freeze Frame:
RPM: 720 /min
Load: 29.8 %
Speed: 0.0 km/h
Temperature: 49.0°C
Readiness: 0000 0001
Забугровый Passat B6 2007г.,FSI 2.0 BVY, tiptronik, comfort, велюрчик, диодики, RCD 500, О w О, no EGR, прошил по Euro-2, зимой заводится!
komsa64
Re: Помогите с ошибками BVY
Сообщение komsa64 » 30 апр 2015, 00:40
После сбросил их,чек больше не горит- иногда глохнет в пробке или на месте?!
как быть?
komsa64
Сообщение 3D_max » 30 апр 2015, 07:15
смотри пропуски по цилиндрам через измеряемые группы, похоже катушка на 3 умирает
3D_max
Сообщение komsa64 » 30 апр 2015, 11:15
Спасибо! У была такая мысль про катушку, вот только не понятно почему глохнет двигатель иногда даже на холостых и даже обороты не плавают при этом! Мистика)))
komsa64
Сообщение 3D_max » 30 апр 2015, 19:07
komsa64 писал(а):Спасибо! У была такая мысль про катушку, вот только не понятно почему глохнет двигатель иногда даже на холостых и даже обороты не плавают при этом! Мистика)))
потому что у тебя с давлением топлива иногда беда, первая ошибка
3D_max
Сообщение shlerik » 01 май 2015, 21:57
Насос помирает в баке вот и глохнет. скоро совсем не заведешь :(
Vag-com 12.12
shlerik
Сообщение komsa64 » 02 май 2015, 07:33
Как вылечить? фильтр, чистить сетку или сам насос менять?
komsa64
Сообщение 3D_max » 02 май 2015, 08:00
komsa64 писал(а):Как вылечить? фильтр, чистить сетку или сам насос менять?
там все всборе
3D_max
Сообщение ввв800 » 02 май 2015, 18:54
насос в баке меняй. такая же ошибка была р1063 и глохла в пробках. поменял все пропало тьфу тьфу тьфу :D
ввв800
Сообщение komsa64 » 02 май 2015, 19:18
спасибо за инфу!!!
komsa64
Сейчас этот форум просматривают: Google [Bot] и гости: 46
