Помогите разобраться с турбиной
Сообщение AndreiYur'evich » 16 авг 2016, 22:04
Ошибка вот такая!
000665 - Boost Pressure Regulation
P0299 - 000 - Control Range Not Reached - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 0
Fault Frequency: 33
Reset counter: 255
Mileage: 115701 km
Time Indication: 0
Date: 2016.06.14
Time: 17:59:40
Freeze Frame:
RPM: 2499 /min
Load: 90.2 %
Speed: 42.0 km/h
Temperature: 80.0°C
Temperature: 39.0°C
Absolute Pres.: 1000.0 mbar
Voltage: 13.970 V
Снял логи со 114 и 115 группы(с 3-й передачи газ в пол).
Не понимаю, означает ли что конец клапану N75 или пришел конец турбине?!
1.8 TSI 2008 АКПП
Вот логи:
,Group A:,'114,,,,Group B:,'115,,,,Group C:, Not Running
,,Engine Load,Engine Load,Engine Load,Boost Pressure,,Engine Speed,Engine Load,Boost Pressure,Boost Pressure,,,,,
,TIME,(specified),(spec. corrected),(actual Value),Control (N75),TIME,(G28),,(specified),(actual),TIME,,,,
Marker,STAMP, %, %, %, %,STAMP, /min, %, mbar, mbar,STAMP,,,,
,0.14,159.4,159.4,45.9,2.0,0.30,1840,59.4,1250.0,1020.0,,,,,
,0.45,157.1,157.1,83.5,96.5,0.59,1880,94.0,1740.0,1050.0,,,,,
,0.75,154.9,154.9,96.2,96.5,0.90,1960,102.3,1700.0,1150.0,,,,,
,1.05,151.1,151.1,104.5,96.5,1.20,2040,109.0,1710.0,1240.0,,,,,
,1.36,151.9,151.9,111.3,96.5,1.51,2120,113.5,1730.0,1320.0,,,,,
,1.66,153.4,153.4,116.5,96.5,1.81,2240,118.0,1760.0,1380.0,,,,,
,1.97,154.1,154.1,120.3,96.5,2.12,2320,121.8,1810.0,1450.0,,,,,
,2.27,154.9,154.9,125.6,96.5,2.42,2400,129.3,1830.0,1530.0,,,,,
,2.60,154.9,154.9,133.1,96.5,2.75,2480,135.3,1850.0,1620.0,,,,,
,2.91,154.9,154.9,139.1,96.5,3.06,2560,142.1,1870.0,1690.0,,,,,
,3.22,156.4,156.4,144.4,96.5,3.38,2640,147.4,1890.0,1750.0,,,,,
,3.53,157.1,157.1,148.9,96.5,3.69,2720,151.9,1870.0,1810.0,,,,,
,3.86,157.9,157.9,154.1,87.1,4.02,2840,152.6,1870.0,1830.0,,,,,
,4.17,158.6,158.6,151.1,91.8,4.31,2920,151.9,1860.0,1820.0,,,,,
,4.47,159.4,159.4,152.6,90.6,4.62,2960,157.1,1800.0,1830.0,,,,,
,4.77,158.6,158.6,155.6,90.2,4.92,3040,153.4,1800.0,1810.0,,,,,
,5.10,157.1,157.1,153.4,89.8,5.25,3160,151.9,1790.0,1790.0,,,,,
,5.41,156.4,156.4,152.6,90.2,5.56,3280,151.9,1770.0,1780.0,,,,,
,5.72,154.9,154.9,151.9,89.8,5.87,3360,151.1,1760.0,1780.0,,,,,
,6.02,154.1,154.1,151.1,89.0,6.17,3480,150.4,1760.0,1770.0,,,,,
,6.33,153.4,153.4,151.9,88.2,6.48,3600,151.9,1760.0,1770.0,,,,,
,6.62,153.4,153.4,151.9,87.8,6.76,3680,151.1,1670.0,1780.0,,,,,
,6.92,153.4,153.4,147.4,79.2,7.08,3760,144.4,1650.0,1700.0,,,,,
,7.23,153.4,153.4,141.4,76.1,7.37,3840,139.1,1650.0,1630.0,,,,,
,7.53,152.6,152.6,139.1,76.1,7.69,3960,137.6,1640.0,1610.0,,,,,
,7.84,152.6,152.6,137.6,76.9,7.98,4040,137.6,1640.0,1600.0,,,,,
,8.14,153.4,153.4,137.6,77.6,8.30,4120,136.8,1650.0,1600.0,,,,,
,8.45,153.4,153.4,136.8,79.6,8.59,4200,136.1,1640.0,1610.0,,,,,
,8.75,154.1,154.1,137.6,82.0,8.90,4280,136.1,1640.0,1620.0,,,,,
,9.05,154.1,154.1,137.6,86.7,9.20,4360,137.6,1650.0,1620.0,,,,,
,9.36,154.9,154.9,138.3,90.6,9.51,4440,137.6,1670.0,1640.0,,,,,
,9.66,154.9,154.9,137.6,93.7,9.81,4520,139.1,1690.0,1660.0,,,,,
,9.97,154.1,154.1,139.1,95.3,10.12,4600,139.8,1710.0,1670.0,,,,,
,10.27,152.6,152.6,141.4,96.5,10.42,4680,139.1,1720.0,1680.0,,,,,
,10.59,151.1,151.1,138.3,96.1,10.73,4760,137.6,1730.0,1680.0,,,,,
,10.87,150.4,150.4,137.6,91.4,11.03,4800,135.3,1750.0,1650.0,,,,,
,11.22,149.6,149.6,134.6,91.0,11.38,4880,136.1,1110.0,1630.0,,,,,
AndreiYur'evich
Re: Помогите разобраться с турбиной
Сообщение pahan71 » 16 авг 2016, 22:32
Тут в форуме написано очень много, читай... У меня тоже самое было и есть вразумительного ответа не найдешь -вердикт турбокомлекс менять!!!)))
Езжу на Б-6 variant, двс - ВМР, 140 л/с, 6 ступ механика.
pahan71
Сообщение pahan71 » 16 авг 2016, 22:33
Опиши симптомы машины
pahan71
Сообщение AndreiYur'evich » 16 авг 2016, 22:42
pahan71 писал(а):Опиши симптомы машины
Ничего серьезного не происходит, только вялая тяга на низах, ну это по логам видно!
До 3000 спокойной, потом толчок и поехала!
AndreiYur'evich
Сейчас этот форум просматривают: Google [Bot] и гости: 17
