Подскажите причину CHECK ENGINE
Сообщение alexydh569 » 25 янв 2012, 18:36
Уважаемые участники! Подскажите ,кто знает -загорелся ЧЕК - подключил шнурок - получил такой перечень кодов:
Я просто не пойму откуда ноги растут? Заслонки впускных каналов и датчик положения заслонок впускных каналов.
001299 - Incorrect Immobilizer Key
P0513 - 008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 0
Fault Frequency: 6
Mileage: 84719 km
Time Indication: 0
Date: 2012.01.19
Time: 20:34:05
Freeze Frame:
RPM: 1340 /min
Load: 14.5 %
Speed: 0.0 km/h
Temperature: 81.0°C
Temperature: 40.0°C
Absolute Pres.: 990.0 mbar
Voltage: 12.065 V
012691 - Intake Manifold Runner Control: Open Stop outside of Valid Range
P3193 - 002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 0
Fault Frequency: 2
Mileage: 84884 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 48.0°C
Temperature: 40.0°C
Absolute Pres.: 1010.0 mbar
Voltage: 12.319 V
001602 - Sensor Reference Voltage A: Circuit: Low
P0642 - 002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Mileage: 84884 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 81.0°C
Temperature: 38.0°C
Absolute Pres.: 1000.0 mbar
Voltage: 12.446 V
008196 - Intake Manifold Flap; Bank 1: Stuck Open
P2004 - 008 - Implausible Signal
Freeze Frame:
Fault Status: 01101000
Fault Priority: 0
Fault Frequency: 2
Mileage: 84890 km
Time Indication: 0
Date: 2012.01.23
Time: 20:36:02
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 90.0°C
Temperature: 32.0°C
Voltage: 12.954 V
004248 - Intake Manifold Tuning Valve Position Sensor (G336): Open or Short to Plus
P1098 - 001 - Upper Limit Exceeded - Intermittent - MIL ON
Freeze Frame:
Fault Status: 10100001
Fault Priority: 0
Fault Frequency: 1
Mileage: 84936 km
Time Indication: 0
Date: 2012.01.24
Time: 16:37:18
Freeze Frame:
RPM: 834 /min
Load: 29.0 %
Speed: 2.0 km/h
Temperature: 93.0°C
Temperature: 33.0°C
Voltage: 13.970 V
Readiness: 0000 0001
VW PASSAT B6 VARIANT 2.0 TFSI BPY 200 л.с. 6ст-АКПП типтрон 09G - продан !!!
alexydh569
Re: Подскажите причину CHECK ENGINE
Сообщение d353vp » 28 янв 2012, 15:27
Во впускном коллекторе есть заслоночки,они имеют привод,а также датчик положения.Двигаются при преодолении порога в 3000-3100 оборотов Вот оттуда и ноги. Все хорошо видно при открытом капоте.Была где-то тема.Поищите.
d353vp
Сообщение Арт » 09 мар 2012, 11:28
Такая же беда. Загорелся чек. В сервисе говорят, что поможет замена датчика-потенциометра g336, который отвечает за работу заслонок во впускном коллекторе. Вопрос: "Поможет ли замена потенциометра или надор менять весь впускной коллектор?"
Passat 1.8 tsi Highline 2 пак. мех.
Арт
Сообщение pashustic » 09 мар 2012, 12:15
Где то здесь упоминалась тема про эти заслоночки, там даже кто-то их чистил, помогало!!
Сообщение Арт » 09 мар 2012, 12:28
Все обыскал, ничего подходящего по данной тематике не нашел. Боюсь отвалю сейчас на замену потенциометра 8000, а не поможет. Вот и думаю, не проще ли купить впускной коллектор целиком?
Арт
