загорелся чек
загорелся чек
Сообщение Dmitriy.Strebkov » 23 апр 2014, 22:30
Здравствуйте, купил себе пассат б6, подцепил шнурок, выдал следующие ошибки, подскажите что они значат и что вообще делать, просто владею первой иномаркой не знаю что делать, двигатель BZB 1.8 160 лс
008213 - Intake Manifold Flap Position Sensor (Bank 1)
P2015 - 000 - Implausible Signal
Freeze Frame:
Fault Status: 01100000
Fault Priority: 0
Fault Frequency: 35
Reset counter: 255
Mileage: 78251 km
Time Indication: 0
Date: 2000.00.00
Time: 15:13:59
Freeze Frame:
RPM: 746 /min
Load: 18.4 %
Speed: 0.0 km/h
Temperature: 83.0°C
Temperature: 44.0°C
Absolute Pres.: 990.0 mbar
Voltage: 13.970 V
000665 - Boost Pressure Regulation
P0299 - 000 - Control Range Not Reached - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 0
Fault Frequency: 27
Reset counter: 255
Mileage: 78359 km
Time Indication: 0
Date: 2000.00.00
Time: 11:27:54
Freeze Frame:
RPM: 2844 /min
Load: 79.6 %
Speed: 63.0 km/h
Temperature: 80.0°C
Temperature: 18.0°C
Voltage: 13.970 V
000564 - Boost Pressure Regulation
P0234 - 000 - Limit Exceeded (Overboost Condition)
Freeze Frame:
Fault Priority: 0
Fault Frequency: 27
Reset counter: 255
Mileage: 78057 km
Time Indication: 0
Date: 2000.00.00
Time: 17:21:52
Freeze Frame:
RPM: 3280 /min
Load: 64.3 %
Speed: 95.0 km/h
Temperature: 94.0°C
Temperature: 9.0°C
Absolute Pres.: 970.0 mbar
Voltage: 14.097 V
001056 - Catalyst System; Bank 1
P0420 - 000 - Efficiency Below Threshold - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 79027 km
Time Indication: 0
Date: 2000.00.00
Time: 20:16:45
Freeze Frame:
RPM: 2048 /min
Load: 23.1 %
Speed: 75.0 km/h
Temperature: 94.0°C
Temperature: 8.0°C
Voltage: 14.224 V
008851 - Fuel Pressure Regulator Valve (N276)
P2293 - 000 - Mechanical Malfunction - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 79285 km
Time Indication: 0
Date: 2000.00.00
Time: 15:27:41
Freeze Frame:
RPM: 985 /min
Load: 36.5 %
Speed: 2.0 km/h
Temperature: 61.0°C
Temperature: 36.0°C
Voltage: 14.097 V
Readiness: 0000 0000
Dmitriy.Strebkov
Re: загорелся чек
Сообщение Евгений87 » 23 апр 2014, 22:36
Комрад, вы прежде чем писать правила форума прочли?
Есть целая тема viewtopic.php?f=52&t=7865
Евгений87
Re: загорелся чек
Сообщение Dmitriy.Strebkov » 23 апр 2014, 22:50
меня просто конкретно интересует. что делать датчики менять или что то еще делать.особенно интересуют первые две ошибки
Dmitriy.Strebkov
Re: загорелся чек
Сообщение LoReNsSe » 23 апр 2014, 23:11
Может попробуете в поиск код ошибки забить?
VW Passat B6, 2.0fsi АКПП6 Highline OoWoO
LoReNsSe
Вернуться в Ошибки
Сейчас этот форум просматривают: Google [Bot] и гости: 9
