Может кто даст совет как это устранить
Сообщение anton_15 » 02 сен 2014, 21:17
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: 12.12.0.0
Data version: 20130910
VIN: WVWZZZ3CZ8E200202 License Plate: 111
Mileage: 97880km-60819mi Repair Order: 111
Chassis Type: 3C (3C0)
Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 52 53 56 62 69 72 76
VIN: WVWZZZ3CZ8E200202 Mileage: 97880km/60819miles
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: Malfunction 0010
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: Malfunction 0010
44-Steering Assist -- Status: Malfunction 0010
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: Malfunction 0010
56-Radio -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
69-Trailer -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
76-Park Assist -- Status: Cannot be reached 1100
Address 01: Engine (CBA) Labels: None
Part No SW: 03L 906 022 FP HW: 03L 907 309
Component: R4 2,0L EDC G000AG 2645
Revision: --H01--- Serial number: VWZCZ000000000
Coding: 0000078
Shop #: WSC 83968 553 682728
VCID: 78FF0E6B0B2690DEAC3-802D
5 Faults Found:
005784 - Please Check DTC Memory of Steering Wheel Electronics
P1698 - 000 -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 6
Fault Frequency: 1
Reset counter: 255
Mileage: 97885 km
Time Indication: 0
Date: 2000.00.00
Time: 00:58:19
Freeze Frame:
RPM: 0 /min
Speed: 0.0 km/h
Load: 0.0 %
Speed: 0.0 km/h
(no units): 255.0
(no units): 255.0
Bin. Bits: 01000000
001644 - Glow Plug Cylinder 2
P066C - 000 - Short to Ground
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 97885 km
Time Indication: 0
Date: 2000.00.00
Time: 01:14:13
Freeze Frame:
RPM: 0 /min
Speed: 0.0 km/h
Voltage: 11.63 V
Temperature: 17.1°C
Bin. Bits: 00110000
Time: 0.18 s
Temperature: 16.2°C
053271 - Please Check Fault Codes in Control Module for ABS Brakes
U1017 - 000 -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 255
Mileage: 97885 km
Time Indication: 0
Date: 2000.00.00
Time: 01:33:45
Freeze Frame:
RPM: 0 /min
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 12.92 V
Bin. Bits: 11001110
Bin. Bits: 00000000
(no units): 0.0
U1017 - 000 - - MIL ON
Freeze Frame:
Fault Status: 11100000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 97885 km
Time Indication: 0
Date: 2000.00.00
Time: 01:33:47
Freeze Frame:
RPM: 0 /min
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 12.92 V
Torque: 93.0 Nm
Hex Value: 0xFF02
Bin. Bits: 11001110
U1017 - 000 -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 255
Mileage: 97885 km
Time Indication: 0
Date: 2000.00.00
Time: 01:33:47
Freeze Frame:
RPM: 0 /min
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 12.92 V
Bin. Bits: 11001110
Bin. Bits: 00000000
(no units): 0.0
Readiness: 0 0 0 0 1
Address 02: Auto Trans Labels: 02E-300-0xx.lbl
Part No SW: 02E 300 050 D HW: 02E 927 770 AE
Component: GSG DSG 081 1408
Revision: 09908010 Serial number: 00000710040927
Coding: 0000020
Shop #: WSC 04940 001 00001
VCID: 132559C732805386391-8046
No fault code found.
Address 03: ABS Brakes Labels: 3C0-614-109-C4.clb
Part No SW: 3C0 614 109 D HW: 3C0 614 109 D
Component: J104 C4 440 V2 0003
Revision: --020--- Serial number: 00000785250904
Coding: 0010000
Shop #: WSC 00500 935 45725
VCID: 1F4D05F7CE4807E68D9-804A
6 Faults Found:
01042 - Control Module; Not Coded
000 - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Reset counter: 255
Mileage: 97885 km
Time Indication: 0
Date: 2000.00.00
Time: 01:34:25
Freeze Frame:
Speed: 0.0 km/h
Hex Value: 0x0000
Voltage: 12.75 V
Bin. Bits: 00011110
Count: 150
00778 - Steering Angle Sensor (G85)
005 - No or Incorrect Basic Setting / Adaptation
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Reset counter: 255
Mileage: 97885 km
Time Indication: 0
Date: 2000.00.00
Time: 01:34:25
01542 - Yaw Rate Sensor (G202)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Reset counter: 255
Mileage: 97885 km
Time Indication: 0
Date: 2000.00.00
Time: 01:34:25
01423 - Lateral Acceleration Sensor (G200)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Reset counter: 255
Mileage: 97885 km
Time Indication: 0
Date: 2000.00.00
Time: 01:34:25
01279 - Longitudinal Acceleration Sensor (G251)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Reset counter: 255
Mileage: 97885 km
Time Indication: 0
Date: 2000.00.00
Time: 01:34:25
00810 - Sensor 1/2 for Brake Pressure
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Reset counter: 255
Mileage: 97885 km
Time Indication: 0
Date: 2000.00.00
Time: 01:34:25
Address 08: Auto HVAC Labels: 3C0-907-044.lbl
Part No SW: 3C0 907 044 AH HW: 3C0 907 044 AH
Component: ClimatronicPQ46 050 0505
Revision: 00050005 Serial number: 00000000000000
Shop #: WSC 00000 000 00000
VCID: 67DD5D1756980F26359-8032
3 Faults Found:
01272 - Positioning Motor for Central Flap (V70)
000 - -
Freeze Frame:
Fault Status: 01110000
Fault Priority: 3
Fault Frequency: 2
Reset counter: 113
Mileage: 97885 km
Time Indication: 0
Date: 2000.00.00
Time: 01:33:46
00716 - Air recirculation Flap Positioning Motor (V113)
000 - -
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 113
Mileage: 97885 km
Time Indication: 0
Date: 2000.00.00
Time: 01:33:46
01274 - Air Flow Flap Positioning Motor (V71)
000 - -
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 113
Mileage: 97885 km
Time Indication: 0
Date: 2000.00.00
Time: 01:33:46
Address 09: Cent. Elect. Labels: 3C0-937-049-23-M.lbl
Part No SW: 3C0 937 049 H HW: 3C0 937 049 H
Component: Bordnetz-SG H37 1301
Revision: 00H37000 Serial number: 00000005256196
Coding: 00898F211004100000120C000000000000087B075C0000
Shop #: WSC 03245 444 00808
VCID: 2E53E833B9E29E6E36F-807B
Subsystem 1 - Part No: 3C1 955 419 A Labels: 1KX-955-119.CLB
Component: Wischer 290108 003 0205
Coding: 00046997
Shop #: WSC 03245
4 Faults Found:
01502 - Bulb for Rear Fog; Left (L46)
012 - Electrical Fault in Circuit
Freeze Frame:
Fault Status: 01101100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 113
Mileage: 97885 km
Time Indication: 0
Freeze Frame:
ON
Voltage: 12.40 V
ON
ON
OFF
OFF
OFF
01506 - Bulb for Rear Fog; Right (L47)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 113
Mileage: 97885 km
Time Indication: 0
Freeze Frame:
ON
Voltage: 12.95 V
ON
ON
OFF
OFF
OFF
01518 - Bulb for Back-Up Lights; Left (M16)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 113
Mileage: 97885 km
Time Indication: 0
Freeze Frame:
ON
Voltage: 12.95 V
ON
ON
OFF
OFF
OFF
02195 - Dimmer Switch Instrument Panel & Switch Lighting (E20)
009 - Open or Short to Ground - Intermittent
Freeze Frame:
Fault Status: 00101001
Fault Priority: 5
Fault Frequency: 1
Reset counter: 153
Mileage: 97885 km
Time Indication: 0
Freeze Frame:
OFF
Voltage: 13.00 V
OFF
ON
OFF
OFF
OFF
Address 15: Airbags Labels: 5N0-959-655.lbl
Part No SW: 5N0 959 655 J HW: 5N0 959 655 J
Component: J234__00H VW10 HI 1916
Revision: 20013000 Serial number: 003E2PQ5KHXG
Coding: 0012360
Shop #: WSC 00028 790 00004
VCID: 4487AA9B076E043EF0B-8011
Subsystem 1 - Serial number: 6332MTS628760268
Subsystem 2 - Serial number: 6342MTS625830318
Subsystem 3 - Serial number: 6351HTS6U6PJSVNH
Subsystem 4 - Serial number: 6361HTS60BTJSVNH
Subsystem 5 - Serial number: 00000000000000000
Subsystem 6 - Serial number: 00000000000000000
Address 16: Steering wheel Labels: 3C0-953-549-SW20.lbl
Part No SW: 3C0 953 549 A HW: 3C0 953 549 A
Component: Lenksдulenmodul 006 0010
Revision: 00006000 Serial number: 3C9953507C
Coding: 0000014
Shop #: WSC 00229 935 97100
VCID: 2A5BE423850AF24EEA7-807F
2 Faults Found:
00895 - Cruise Control Switch (E45)
014 - Defective
Address 17: Instruments Labels: 3C0-920-xxx-17.lbl
Part No SW: 3C0 920 860 N HW: 3C0 920 860 N
Component: KOMBIINSTRUMENT VD1 1216
Revision: V0002000 Serial number: 00000000000000
Coding: 0007105
Shop #: WSC 19279 643 24704
VCID: 2D51EF3FB4E4E5760F5-8078
Address 19: CAN Gateway Labels: 3C0-907-530-V3.clb
Part No SW: 3C0 907 530 Q HW: 3C0 907 951
Component: J533 Gateway H13 0172
Revision: H13 Serial number: 3620P109220073
Coding: FD807F4E000202002002
VCID: 2F6DF537BEE897663D9-807A
1 Fault Found:
01327 - Control Module for Parking Aid (J446)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 113
Mileage: 97885 km
Time Indication: 0
Address 25: Immobilizer
Cannot be reached
Address 42: Door Elect, Driver Labels: 1K0-959-701-MAX3.lbl
Part No SW: 1K0 959 701 AE HW: 1K0 959 793 P
Component: J386 TUER-SG FT 1519
Revision: 71009005 Serial number: 00000777688619
Coding: 0000180
Shop #: WSC 00066 000 00000
VCID: 71E9334F685CC1966BD-8024
1 Fault Found:
00932 - Electric Window Motor; Drivers Side (V147)
Freeze Frame:
Fault Status: 01100101
Fault Priority: 6
Fault Frequency: 1
Reset counter: 113
Mileage: 97885 km
Time Indication: 0
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K1 909 144 M
Component: EPS_ZFLS Kl.135 H08 1901
VCID: 3561C75F5CB4ADB6775-8060
1 Fault Found:
000 - -
Address 46: Central Conv.
Cannot be reached
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN3.lbl
Component: J387 TUER-SG BT 1123
Revision: 12006001 Serial number: 00000063968615
Coding: 0000180
Shop #: WSC 00028 028 00001
VCID: 3C77D27B7F9E7CFE88B-8069
Address 53: Parking Brake Labels: 3C0-907-801-53.clb
Component: EPB VC8HC001 013 0001
Revision: 013
Coding: 0010000
Shop #: WSC 131071 1023 2097151
VCID: 2149030FF83C3116BBD-8074
4 Faults Found:
02443 - Control Head
012 - Electrical Fault in Circuit - MIL ON
Freeze Frame:
Fault Status: 11111100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 113
Mileage: 97880 km
Time Indication: 0
Date: 2000.00.00
Time: 01:36:04
Freeze Frame:
Voltage: 12.63 V
Count: 40
01316 - ABS Control Module
013 - Check DTC Memory - MIL ON
Freeze Frame:
Fault Status: 11101101
Fault Priority: 3
Fault Frequency: 141
Reset counter: 113
Mileage: 97880 km
Time Indication: 0
Date: 2000.00.00
Time: 01:33:45
Freeze Frame:
Voltage: 12.53 V
Count: 236
000 - - - MIL ON
Freeze Frame:
Fault Priority: 4
Fault Frequency: 254
Reset counter: 131
Time Indication: 0
Date: 2064.00.00
Time: 00:00:00
Freeze Frame:
Voltage: 6.42 V
Count: 171
01087 - Basic Setting Not Performed
000 - - - MIL ON
Freeze Frame:
Fault Priority: 4
Reset counter: 131
Time Indication: 0
Date: 2064.00.00
Time: 00:00:00
Freeze Frame:
Voltage: 6.42 V
Count: 170
Address 56: Radio (J503) Labels: 5M0-035-1xx-56.clb
Part No SW: 1K0 035 186 AA HW: 1K0 035 186 AA
Component: Radio RCD310 016 0049
Revision: 01000000 Serial number: VWZ1Z2K8142736
Coding: 0500040004
VCID: 65C1571F6C941D36075-8030
2 Faults Found:
00821 - Antenna 2 for Radio (R93)
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 5
Fault Frequency: 1
Reset counter: 113
Mileage: 97885 km
Time Indication: 0
Date: 2000.00.00
Time: 01:34:06
03138 - Input AUX IN
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 113
Mileage: 97885 km
Time Indication: 0
Date: 2000.00.00
Time: 01:34:01
Address 62: Door, Rear Left Labels: None
Part No SW: 3C0 959 703 HW: 3C0 959 795
Component: J388 TUER-SG HL 0408
Revision: 41004102 Serial number: 00000002044281
Coding: 0000016
Shop #: WSC 08224 016 26317
VCID: E7DDDD17D6988F26B59-80B2
Address 69: Trailer (J345) Labels: 1K0-907-383-MY8.lbl
Part No SW: 1K0 907 383 D HW: 1K0 907 383 B
Component: Anhaenger H16 0070
Revision: 3A002001 Serial number: 00000109761435
Coding: 0100000200000000
Shop #: WSC 05314 000 00000
VCID: 2E53E83379E29E6E36F-807B
Address 72: Door, Rear Right
Cannot be reached
Address 76: Park Assist
Cannot be reached
Буду признателен за любую помощью Или может посоветуете к кому обратиться
anton_15
Re: Может кто даст совет как это устранить
Сообщение valent77 » 02 сен 2014, 21:50
что тема, что вопрос, можно назвать найди и догадайся сам.
Для начала какой город? Потом что беспокоит. Тем по ошибкам полно.
Сообщение anton_15 » 03 сен 2014, 00:12
Прошу прощения что дал не полную информацию. Нахожусь в г.Королев Московской области. Автомобиль Passat B6 универсал 2.0 TDI DSG6
беспокоит следующее:
Моргает значек спирали свечи
Моргает ABS но работает
Моргает знак ручника но работает
Не работает автохолд
Не работает круиз
Не работают парктроники
В общем ничего не работает :(
anton_15
Сообщение Alemania » 03 сен 2014, 19:28
Слетели кодировки блока стояночного тормоза и блока АБС. Что то меняли ? БЛок стояночного тормоза например или отключали разъем от него ??
Вернуть взад кодировку АБС и Стояночного тормоза, выполнить базовые установки по датчикам поворота ускорения и т.д. ( на что ругается в 3 блоке)
Сообщение anton_15 » 04 сен 2014, 22:11
Alemania писал(а):Слетели кодировки блока стояночного тормоза и блока АБС. Что то меняли ? БЛок стояночного тормоза например или отключали разъем от него ??
А как это сделать, машину уже взял такой. Не могу кодировки эти найти. То что находил он вроде их принимает, но все равно пишет эту же ошибку
anton_15
Сообщение 1gdm » 04 сен 2014, 22:22
Шнурок есть? Подъезжайте на ВДНХ,глянем.. Двиг CBA,2008 года,правильно? У товарища CBAB 2008,мож даст кодировки посмотреть..
Сообщение anton_15 » 04 сен 2014, 22:34
Шнур есть, когда там бываете?
anton_15
Сообщение 1gdm » 05 сен 2014, 11:09
anton_15 писал(а):Шнур есть, когда там бываете?
В ЛС
Сообщение Blackangel » 05 сен 2014, 14:00
Офигеть рассадник ошибок! Тоже такое было когда автос простоял месяц без аккумулятора. Почти все кодировки забыл. Пришлось к оффам ехать кодировать.
Там ошибки одна за одну цепляются, выскочила одна, а за ней еще 10 из-за нее!
Димас на Пассате)))
Blackangel
Вернуться в Ошибки
Сейчас этот форум просматривают: Google [Bot] и гости: 9
