Ошибка по камере заднего вида
Сообщение febr72 » 28 фев 2015, 18:13
Всем доброго времени суток! Камера заднего вида работает, но выскакивает ошибка. Подскажите, в чем проблема? Заранее спасибо!
Chassis Type: 7N0
Scan: 01 02 03 08 09 10 15 16 17 19 25 2E 36 37 42 44 46 4F 52 53
55 56 62 65 6C 72 77
VIN: WVWZZZ3CZDP039480
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
2E-Media Player 3 -- Status: OK 0000
36-Seat Mem. Drvr -- Status: OK 0000
37-Navigation -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
4F-Centr. Electr. II -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
55-Xenon Range -- Status: OK 0000
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
65-Tire Pressure -- Status: OK 0000
6C-Back-up Cam. -- Status: Malfunction 0010
72-Door, Rear Right -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 6C: Back-up Cam. Labels: None
Part No SW: 3AE 907 441 HW: 3AE 907 441
Component: J772__Rearview 0020
Revision: 00H11000 Serial number: 525 PA8J2Z2727
Coding: 0020006
Shop #: WSC 00028 028 00001
VCID: F2EF5EFB966F
1 Fault Found:
01317 - Control Module in Instrument Cluster (J285)
013 - Check DTC Memory
Freeze Frame:
Fault Status: 01101101
Fault Priority: 6
Fault Frequency: 1
Reset counter: 152
Mileage: 23147 km
Time Indication: 0
Date: 2022.14.07
Time: 18:38:21
Freeze Frame:
Term 15 On
Reverse OFF
Count: 3
febr72
Вернуться в Ошибки
