ребята помогите с решением этих ошибок
Сообщение ДЕМОС » 01 июн 2015, 22:39
PASSAT B6 2.0 FSI BVY
МАГНИТОЛУ ХУЛИГАНЫ ВЫТАЩИЛИ :cry:
[Monday,01,June,2015,22:59:42:62939
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: 12.12.0.0
Data version: 20130910
VIN: WVWZZZ3CZ6P212217 License Plate: 01.06.2015
Mileage: 150360km-93429mi Repair Order:
Chassis Type: 3C (3C0)
Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 52 53 56 62 72
VIN: WVWZZZ3CZ6P212217 Mileage: 150360km/93429miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: Sporadic communication error 1000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
56-Radio -- Status: Cannot be reached 1100
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
Address 01: Engine Labels: Redir Fail!
Part No SW: 06F 997 058 R HW: Hardware No
Component: MED9.5.10 G00 2770
Revision: 69H03--- Serial number: VWZCZ000000000
Coding: 0000075
Shop #: WSC 00104 935 89590
VCID: 4487AA9B076E043EF0B-8011
1 Fault Found:
006419 - Pressure Sensor for Brake Boost (G294)
P1913 - 008 - Short to Ground - Intermittent-ПОВТОРНАЯ ОШИБКА У ЖЕ БЫЛА УДАЛЯЛ И СНОВА ВЫЛЕЗЛА
Freeze Frame:
Fault Status: 00101000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 150182 km
Time Indication: 0
Date: 2000.00.00
Time: 15:10:02
Freeze Frame:
RPM: 760 /min
Load: 35.3 %
Speed: 0.0 km/h
Temperature: 43.0°C
Readiness: 0000 0000
Address 02: Auto Trans
Cannot be reached
Address 03: ABS Brakes Labels: 3C0-614-095-C2.clb
Part No SW: 3C0 614 095 Q HW: 3C0 614 095 Q
Component: ESP 440 C2 H015 0003
Revision: H015 Serial number: 0667397958
Coding: 0046481
Shop #: WSC 00028 028 00001
VCID: 306FF64BA3D6889E243-8065
No fault code found.
Address 08: Auto HVAC Labels: 3C0-907-044.lbl
Part No SW: 3C0 907 044 AD HW: 3C0 907 044 AD
Component: ClimatronicPQ46 050 0404
Revision: 00050005 Serial number: 00000000000000
Shop #: WSC 00000 000 00000
VCID: 63C54907A2A06306E91-8036
1 Fault Found:
01274 - Air Flow Flap Positioning Motor (V71)
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 3
Fault Frequency: 1
Reset counter: 81
Mileage: 150321 km
Time Indication: 0
Date: 2000.00.00
Time: 17:19:45
Address 09: Cent. Elect. Labels:
VCID: 55A167DFBCF48DB6975-8000
Address 15: Airbags Labels: 3C0-909-605.lbl
Part No SW: 3C0 909 605 J HW: 3C0 909 605 J
Component: 04 AIRBAG VW8 029 2521
Revision: 09029000 Serial number: 003A2P4WYLWY
Coding: 0012340
VCID: 2D51EF3FB4E4E5760F5-8078
Subsystem 1 - Serial number: 6332MSME0E6C725B
Subsystem 2 - Serial number: 6342MSME0F3A4279
Subsystem 3 - Serial number: 6351HTS6OLLEKJ93
Subsystem 4 - Serial number: 6361HTS6TLL6T533
Subsystem 5 - Serial number: 00000000000000000
Subsystem 6 - Serial number: 00000000000000000
Address 16: Steering wheel Labels: 3C0-953-549-SW20.lbl
Part No SW: 3C0 953 549 A HW: 3C0 953 549 A
Component: Lenksдulenmodul 005 0010
Revision: 00005000 Serial number: 3C5953507B
Coding: 0001011
VCID: 2A5BE423850AF24EEA7-807F
Address 17: Instruments Labels: 3C0-920-xxx-17.lbl
Part No SW: 3C0 920 851 J HW: 3C0 920 851 J
Component: KOMBIINSTRUMENT VD1 4242
Revision: V0043000 Serial number: 00000000000000
Coding: 0007105
Shop #: WSC 00104 935 21347
VCID: 29591B2F800CF956E3D-807C
Address 19: CAN Gateway Labels: 3C0-907-530-V1.clb
Component: Gateway 007 0040
Revision: 00007000 Serial number: 0700C0632807F9
Coding: 3FFD0C04C21002
VCID: 2149030FF83C3116BBD-8074
3 Faults Found:
01305 - Databus for Infotainment
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 1
Fault Frequency: 1
Reset counter: 32
Mileage: 150193 km
Time Indication: 0
Date: 2000.00.00
Time: 17:02:29
01304 - Radio
Freeze Frame:
Fault Priority: 2
Fault Frequency: 44
Reset counter: 39
Mileage: 150193 km
Time Indication: 0
Date: 2000.00.00
Time: 17:09:38
01331 - Door Control Module; Driver Side (J386)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 87
Mileage: 150348 km
Time Indication: 0
Date: 2000.00.00
Time: 13:32:16
Address 25: Immobilizer Labels: 3C0-959-433-25.clb
Part No SW: 3C0 959 433 K HW: 3C0 959 433 K
Component: IMMO 038 0367
Revision: 00038000 Serial number: VWZCZ000000000
Shop #: WSC 131071 1023 2097151
VCID: 326BFC43ADDABA8E527-8067
Subsystem 1 - Part No: 3C0 905 861 D
Component: ELV 024 0370
3C0905861D ELV 024 0370
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN2.lbl
Part No: 1K0 959 701 K
Component: Tuer-SG 024 2801
Coding: 0000181
VCID: 3663C05341B2A6AE7EF-8063
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K1 909 144 K
Component: EPS_ZFLS Kl.5 D06 1701
VCID: 3365F94752C0B386591-8066
Address 46: Central Conv. Labels: 3C0-959-433-46.clb
Component: KSG PQ46 ELV 038 0455
Coding: 00910A0801860E763804941570084FCE703880
Subsystem 1 - Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H03 1301
Subsystem 2 - Part No: 3C0 951 171 A
Component: Neigungssensor 002 0508
Subsystem 3 - Part No: 3C0 951 171 A
Component: Innenraumueberw.002 0508
1 Fault Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 87
Mileage: 150348 km
Time Indication: 0
Date: 2000.00.00
Time: 13:32:16
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN2.lbl
Part No: 1K0 959 702 K
Coding: 0000180
VCID: 377DCD5746B85FA6659-8062
Address 53: Parking Brake Labels: 3C0-907-801-53.clb
Component: EPB VC8HC001 013 0001
Revision: 013
Coding: 0000012
Address 56: Radio
Cannot be reached
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN2.lbl
Part No: 1K0 959 703 F
Component: Tuer-SG 021 2436
Coding: 0000144
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN2.lbl
Part No: 1K0 959 704 F
Coding: 0000144
VCID: 3467FA5B57CEB4BE40B-8061
End --------------------------------------------------------------------- :o :o :o :o :o :o
Последний раз редактировалось ДЕМОС 01 июн 2015, 23:22, всего редактировалось 1 раз.
ДЕМОС
Re: ПОМОГИТЕ РАСШИФРОВАТЬ ВСЕ ЭТ ОШИБКИ И ПОСОВЕТУЙТЕ ЧТО ДЕЛАТЬ
Сообщение ДЕМОС » 01 июн 2015, 23:04
P1913 Датчик давления для усилителя тормозов-G294, короткое замыкание на массу- под замену?
ДЕМОС
Сообщение N1TRO » 01 июн 2015, 23:14
ДЕМОС писал(а):P1913 Датчик давления для усилителя тормозов-G294, короткое замыкание на массу- под замену?
Нет такого датчика!Есть двойной датчик G483 и G294 в одном флаконе,стоит снизу на вакуумнике за аккумуляторной площадкой!
N1TRO
Re: ребята помогите с решением этих ошибок
Сообщение ДЕМОС » 01 июн 2015, 23:26
а у него номер то хоть есть?
ДЕМОС
чтобы пробить по каталогу???
ДЕМОС
Сообщение ДЕМОС » 01 июн 2015, 23:29
да еще двигло троит при прогреве и потряхивает после прогрева, заменил клапан вгк и трубки выпуска отработанных картерных газов !!!!
и пропала тяга
ДЕМОС
Сообщение ДЕМОС » 01 июн 2015, 23:30
и климат еле еле хладит воздух
ДЕМОС
Сообщение N1TRO » 01 июн 2015, 23:36
ДЕМОС писал(а):а у него номер то хоть есть?
Да,есть!Стоит прилично! Вот 1K0 998 213
N1TRO
Сообщение ДЕМОС » 01 июн 2015, 23:38
а из-за чего он мог навернуться???
ДЕМОС
Сообщение ДЕМОС » 01 июн 2015, 23:48
а по остальным ошибкам что скажите господа??? кроме магнитолы и радио!))))
ДЕМОС
Вернуться в Ошибки
