Не работает поворотный свет
Сообщение Jek » 20 май 2016, 07:00
Не работает поворотный свет, выдает такие ошибки, куда копать, что делать?
Wednesday,18,May,2016,16:39:16:10074
VCDS Version: Release 10.6.4 (x64)
Data version: 20110418
Address 55: Xenon Range Labels: 5M0-907-357-V1.lbl
Control Module Part Number: 5M0 907 357 HW: 5M0 907 357
Component and/or Version: AFS-Steuergeraet 0003
Software Coding: 0000001
Work Shop Code: WSC 00028 028 00001
Additional Info: ID-L fehlt AFS-Lst.-Modul l .... ID-R fehlt AFS-Lst.-Modul r ....
VCID: F1ED51F79139
6 Faults Found:
01042 - Control Module; Not Coded
000 - - - MIL ON
Freeze Frame:
Fault Status: 11100000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 19
Time Indication: 0
02656 - Power Output Stage for Left Headlight (J667); Not Coded
000 - - - MIL ON
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 19
Time Indication: 0
02657 - Power Output Stage for Right Headlight (J668); Not Coded
000 - - - MIL ON
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 19
Time Indication: 0
01539 - Headlights Not Adjusted
005 - No or Incorrect Basic Setting / Adaptation - MIL ON
Freeze Frame:
Fault Status: 11100101
Fault Priority: 2
Fault Frequency: 1
Reset counter: 19
Time Indication: 0
02233 - Left Headlight Power Output Stage (J667)
004 - No Signal/Communication - MIL ON
Freeze Frame:
Fault Status: 11100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 19
Mileage: 150241 km
Time Indication: 0
Date: 2016.05.18
Time: 16:36:25
02234 - Right Headlight Power Output Stage (J668)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 19
Mileage: 150241 km
Time Indication: 0
Date: 2016.05.18
Time: 16:36:25
Passat B6, 2.0 FSI,BVY, 6-АКПП, 2006
Jek
Вернуться в Ошибки
