Сообщение kop » 18 окт 2016, 21:00
Alemania писал(а):
kop писал(а):Почему сканирование VCDS 12.12 не выдаёт никаких ошибок, а "Протолок диагностики (длинный)" из Offboard Diagnostic Information System из АвтоГанзы выдал ошибки?
а где скан то ??
Monday,17,October,2016,22:32:43:62939
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: Release 12.12.0 (x64)
Data version: 20130910
VIN: License Plate:
Mileage: 94080km-58458mi Repair Order:
Chassis Type: 3C (3C0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 53 56 62 72
VIN: Mileage: 94080km/58458miles
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
Address 01: Engine Labels: Redir Fail!
Part No SW: 06F 997 058 P HW: 06F 906 056 EK
Component: MED9.5.10 G00 3192
Revision: 69H04--- Serial number: VWZCZ000000000
Coding: 0000072
Shop #: WSC 00102 935 179055
VCID: 428BAC831D7A0A0EC27-8017
No fault code found.
Readiness: 1000 0000
Address 03: ABS Brakes Labels: 3C0-614-109-C4.clb
Part No SW: 3C0 614 109 C HW: 3C0 614 109 C
Component: J104 C4 440 V1 0003
Revision: --020--- Serial number: 00000775808674
Coding: 0004429
Shop #: WSC 00028 028 00001
VCID: 1E3338F3C9420EEE86F-804B
Address 08: Auto HVAC Labels: 3C0-907-044.lbl
Part No SW: 3C0 907 044 CC HW: 3C0 907 044 CC
Component: ClimatronicPQ46 122 0707
Revision: 00122021 Serial number: 00000000000000
Shop #: WSC 00000 000 00000
VCID: 64C74A1BA7AE643E10B-8031
Address 09: Cent. Elect. Labels: 3C0-937-049-30-M.lbl
Part No SW: 3C0 937 049 AK HW: 3C0 937 049 AK
Component: Bordnetz-SG H54 2202
Revision: 00H54000 Serial number: 01000005029221
Coding: E4848F0700041A00470A00000F000000000D59435C000100000000000000
VCID: 72EB3C436D5AFA8E927-8027
Subsystem 1 - Part No: 3C1 955 419 A Labels: 1KX-955-119.CLB
Component: Wischer 210607 003 0205
Coding: 00046997
Shop #: WSC 00028
Subsystem 2 - Part No: 1K0 955 559 AF Labels: 1K0-955-559-AF.CLB
Component: RLS 200707 046 0204
Coding: 00208933
Shop #: WSC 00028
Address 15: Airbags Labels: 3C0-909-605.lbl
Part No SW: 3C0 909 605 M HW: 3C0 909 605 M
Component: 0B AIRBAG VW8 032 2522
Revision: 12032000 Serial number: 003B1PDZ1CAP
Coding: 0012354
VCID: 306FF64BA3D6889E243-8065
Subsystem 1 - Serial number: 6332MSME155A050B
Subsystem 2 - Serial number: 6342MSME1B6D414C
Subsystem 3 - Serial number: 6351HTS618L4K466
Subsystem 4 - Serial number: 6361HTS618LSK2N6
Subsystem 5 - Serial number: 00000000000000000
Subsystem 6 - Serial number: 00000000000000000
Address 16: Steering wheel Labels: 3C0-953-549-SW20.lbl
Part No SW: 3C0 953 549 L HW: 3C0 953 549 L
Component: Lenksдulenmodul 006 0010
Revision: 00006000 Serial number: 3C5953507BK
Coding: 0000013
VCID: 3561C75F5CB4ADB6775-8060
Address 17: Instruments Labels: 3C0-920-xxx-17.lbl
Part No SW: 3C0 920 860 M HW: 3C0 920 860 M
Component: KOMBIINSTRUMENT VD1 1216
Revision: V0002000 Serial number: 00000000000000
Coding: 0007105
Shop #: WSC 00102 935 177015
VCID: 2C57E23B8FFEEC7E18B-8079
Address 19: CAN Gateway Labels: 3C0-907-530-V2.clb
Part No SW: 3C0 907 530 E HW: 3C0 907 951
Component: J533__Gateway H10 0080
Revision: H10 Serial number: 1200P0770903E2
Coding: F9807F060002021002
VCID: 23450907E2202306A91-8076
Address 25: Immobilizer Labels: 3C0-959-433-25.clb
Part No SW: 3C0 959 433 AR HW: 3C0 959 433 AR
Component: IMMO 043 0383
Revision: 00043000 Serial number: VWZCZ000000000
Shop #: WSC 00102 935 176987
VCID: 7AFB1463352A82CEDA7-802F
Subsystem 1 - Part No: 3C0 905 861 G
Component: ELV 027 0380
3C0905861G ELV 027 0380
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN3.lbl
Component: J386 TUER-SG FT 1131
Revision: 32008001 Serial number: 00000072378714
Coding: 0000245
VCID: 3B75D1677A907BC6811-806E
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K1 909 144 M
Component: EPS_ZFLS Kl.133 H08 1901
Shop #: WSC 00102 935 182978
Address 46: Central Conv. Labels: 3C0-959-433-46.clb
Component: A_ KSG PQ46 ELV 043 0612
Coding: 00910A0001860E763004941570084F0E707CA1
Subsystem 1 - Part No: 1K0 951 605 D
Component: LIN BACKUP HORN H07 9001
Subsystem 2 - Component: NGS n.mounted
Subsystem 3 - Component: IRUE n.mounted
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN3.lbl
Component: J387 TUER-SG BT 1131
Revision: 32008001 Serial number: 00000653778715
Coding: 0000244
VCID: 3C77D27B7F9E7CFE88B-8069
Address 53: Parking Brake Labels: 5N0-907-801.clb
Part No SW: 3C0 907 801 J HW: 3C0 907 801 J
Component: J540 EPB3 VW-09393 0009
Revision: 008 Serial number: 00000000099955
Coding: 0000056
VCID: 29591B2F800CF956E3D-807C
Address 56: Radio Labels: 1K0-035-1xx-56.lbl
Part No: 1K0 035 186 AD
Component: Radio GR0 033 0033
Revision: 0003303S Serial number: VWZ2Z2G1960440
Coding: 0020200
VCID: 68DF5E2B5B86005E3C3-803D
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN3.lbl
Part No SW: 1K0 959 703 P HW: 1K0 959 795 G
Component: J388 TUER-SG HL 1118
Revision: 11006001 Serial number: 00000002077809
Coding: 0000208
VCID: 3D71DF7F648475F6BF5-8068
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN3.lbl
Part No SW: 1K0 959 704 P HW: 1K0 959 794 G
Component: J389 TUER-SG HR 1118
Revision: 11006001 Serial number: 00000002081100
Coding: 0000208
VCID: 3E73D87369826EEEA6F-806B
End ---------------------------------------------------------------------
не выдаёт никаких ошибок, а "Протолок диагностики (длинный)" из Offboard Diagnostic Information System из АвтоГанзы в прикреплённом файле выдал ошибки?
Где в VCDS 12.12 увидеть эти ошибки, которые нашёл Offboard Diagnostic Information System?
из Автоганзы.pdf
Последний раз редактировалось kop 18 окт 2016, 21:35, всего редактировалось 2 раз(а).
Passat B6 2.0 FSI BVY, свечи NGK 7742 PZFR5N-11T, 6МКПП - 02SB JYL, маховик+сцепление SACHS 2290601053, Highline, Сен. 2007, пробег 105т.км
kop
Сообщение Daniliv » 18 окт 2016, 21:01
Зачем такую Грамоту кидать.
Сообщение kop » 18 окт 2016, 21:14
Daniliv писал(а):Зачем такую Грамоту кидать.
Я заменил на прикреплённый файл.
kop
Сообщение Alemania » 19 окт 2016, 10:36
kop
из 45 страниц всякой хрени увидел только ошибки по низкому напряжению и поворотник в левом зеркале. Непостоянно. Ошибки могли стереть. Появление ошибок - история умалчивает.
Сообщение kop » 19 окт 2016, 10:49
Alemania писал(а):kop
Спасибо за ответ!
Ошибки не стирали. Где эти ошибки можно увидеть в VCDS 12.12?
Как увидеть текущее напряжение питания погружного бензонасоса, или ближе к нему?
kop
Сообщение Андрей 1988 » 19 окт 2016, 12:02
kop писал(а):Как увидеть текущее напряжение питания погружного бензонасоса, или ближе к нему?
Снимите заднее сидение и тестером проверьте на фишке насоса...
Смотрите: Эбу двигателя с блоком управления насоса(черная коробочка рядом с насосом) общается по ШИМ и исходя из потребностей ДВС по топливу Б/У насосом подает на насос определенное напряжение :o
Например на Рхх на прогретом моторе давление в магистрали низкого давления может быть 0,5 бар, а высокое 30 бар.
Андрей 1988
Сообщение kop » 19 окт 2016, 13:25
Спасибо за ответ!
Что такое ШИМ?
Pxx - холостые обороты? У меня на холостых давление ТНВД - 40 бар, а не 30 в 106 группе.
Как снять заднее сидение?
К каким двум контактам нужно прикладывать щупы тестера? Какое там напряжение примерно? Прикладывать при подсоединённом и работающем насосе?
В VCDS 12.12 можно посмотреть напряжение, идущее к насосу?
kop
Сообщение Саныч » 19 окт 2016, 15:01
Приветствую! Подскажите в таком вопросе. Обогрев пятой точки передних сидений раньше работал как включил на "5" так и шпарит постоянно на "5" пока не выключишь, а с конца прошлой зимы начал работать в режиме "догрел до 5 и выключился совсем". С чем это может быть связано и возможно ли это по причине сброса каких-либо настроек в блоке отвечающим за обогрев? Может шнурком надо где подкорректировать.
Passat B6 1.4 TSI caxa DSG7 черный 0W0
Саныч
Сообщение Юра Криков » 19 окт 2016, 15:48
kop писал(а):Как снять заднее сидение?
Поиском,дружище,поиском ;) -
viewtopic.php?f=48&t=7765
Сообщение boroda II » 19 окт 2016, 19:07
Спасибо за ответ!
Что такое ШИМ?
Если уж решился сам все чинить, то скачай ETKA и ELSA там все расписано что снимать, как мерить и какой специнструмент может понадобиться по всей машине.
Сообщение Андрей 1988 » 19 окт 2016, 19:10
kop
Вот описание работы насоса, может поможет вам :?
Андрей 1988
Сообщение kop » 20 окт 2016, 12:09
Спасибо за ответ!
Что такое ШИМ?
ETKA была переименована в http://www.oemepc.com/ ? От куда скачать?
kop
Сообщение kop » 20 окт 2016, 12:16
Андрей 1988 писал(а):kop
Спасибо! Из какой это книжки?
В ней написано, что после замены насоса нужно сделать адаптацию через ведомый поиск неисправностей. Ведомый поиск неисправностей можно сделать только у диллера или с использованием дорогого адаптера. То есть заменить насос можно только у диллера или если есть этот дорогой адаптер?
kop
Сообщение boroda II » 20 окт 2016, 16:35
По факту ничего не нужно, меняешь насос , стираешь ошибки и ездишь.
Сообщение Андрей 1988 » 21 окт 2016, 15:19
kop писал(а):Спасибо! Из какой это книжки?
http://vwts.ru/pps/pps_seat_103_motroni ... 10_rus.pdf
kop писал(а):В ней написано, что после замены насоса нужно сделать адаптацию через ведомый поиск неисправностей. Ведомый поиск неисправностей можно сделать только у диллера или с использованием дорогого адаптера. То есть заменить насос можно только у диллера или если есть этот дорогой адаптер?
Верно написал!Можно ничего не адаптировать...
Андрей 1988
Сообщение kop » 21 окт 2016, 17:01
Ссылка не работает. Исправьте, пожалуйста, ссылку.
kop
Сообщение morpeh » 21 окт 2016, 17:08
Да вроде всё работает!
+7 911 891 71 41
morpeh
Сообщение Андрей 1988 » 21 окт 2016, 17:38
У меня работает!
Вот Еще раз http://vwts.ru/pps/pps_seat_103_motroni ... 10_rus.pdf
Андрей 1988
Сообщение saylau » 28 окт 2016, 20:35
привет всем отключил через васю датчики давления шин, все равно загорается через какоето время
Passat BPY тфси 2005г
saylau
Сообщение Alemania » 28 окт 2016, 21:21
saylau писал(а):привет всем отключил через васю датчики давления шин, все равно загорается через какоето время
1 что отключил (косвенное или прямое)
2 где отключил (в каком блоке, байте )
3 как отключил
Сообщение saylau » 28 окт 2016, 21:56
3 как отключил
гасим "tire pressure too low!"
- заходим в блок "контроль давления в шинах" он есть в главном меню "подвеска"
- жмём "адаптация"
- выбираем канал 02
- меняем значение с 1 на 2
- жмём тест
- жмем сохранить
- пьём пиво
Взято отсюда: http://www.passat-club.ru/forum/threads/27289-Переставить-датчик-давления-в-шинах/page4
saylau
Сообщение Alemania » 28 окт 2016, 22:14
в гейте галку тоже снял ?
Сообщение saylau » 28 окт 2016, 23:28
Alemania писал(а):в гейте галку тоже снял ?
это где
saylau
Сообщение Daniliv » 29 окт 2016, 11:55
Это в Гейте.
Сообщение Андрей 1988 » 29 окт 2016, 18:57
Я только в гейте галку снимал и ошибка с приборки уходила...в блоке давления шин ошибка по неправильной кодировке остаётся!, но она не мешает :D
Андрей 1988
