PROBLEMA S IMMOBILAIZEROM I PARKOVOCHNIM TORMOZOM
Сообщение Andron2555 » 31 дек 2013, 18:17
Dobroe vremja sutok! Pomogite, please, u menja voznikli problemi s immobilaizerom da i ne tolko posle remonta odnim specialistom. Seichas situacija takaja. Mashina zavoditsja bez problem, no kogda vitaskivaesh kljuch, idut 3 shelchka blokirovki rulja, no ruili blokiruetsja s pervogo shelchka i na displee nachinaet migati zjoltii ruli. Takze kogda zakrivaesh mashinu kljuchom, to fari perestali migati, a na otkritie migajut. Do remonta takogo ne bilo. I eshjo postojanno gorit na panele zeltaja lampochka parkovochnogo tormoza. Do remonta mashina prosto inogda ne zavodilasi, no takih bed ne bilo. Mozet kto podskazet v chjom mozet biti prichina i chto nuzno v pervuju ocheredi proveriti. Zaranee blagodaren. Vot oshibki, kotorie dala diagnostika.
Address 25: Immobilizer Labels: 3C0-959-433-25.lbl
Part No SW: 3C0 959 433 K HW: 3C0 959 433 K
Component: IMMO 038 0367
Revision: 00038000 Serial number: VWZCZ000000000
Shop #: WSC 131071 1023 2097151
Part No: 3C0 905 861 D
Component: ELV 024 0370
3C0905861D ELV 024 0370
3 Faults Found:
02823 - Requirements for Locking the Steering Column Lock not met
000 - - - Intermittent
Freeze Frame:
Fault Status: 00110000
Fault Priority: 7
Fault Frequency: 1
Reset counter: 25
Mileage: 150822 km
Time Indication: 0
Date: 2000.00.00
Time: 12:31:55
02827 - Wake-Up request via ESP
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 25
Mileage: 150822 km
Time Indication: 0
Date: 2000.00.00
Time: 12:31:55
02811 - Control Module for Electronic Steering Column Lock (J764)
014 - Defective - Intermittent
Freeze Frame:
Fault Status: 00101110
Fault Priority: 1
Fault Frequency: 1
Reset counter: 4
Mileage: 149844 km
Time Indication: 0
Date: 2000.00.00
Time: 20:31:59
Address 53: Parking Brake Labels: 3C0-907-801-53.lbl
Component: EPB VC8HC001 013 0001
Revision: 013
Coding: 0000012
Shop #: WSC 00028 028 00001
2 Faults Found:
02443 - Control Head
012 - Electrical Fault in Circuit - Intermittent
Freeze Frame:
Fault Status: 00101100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 252
Mileage: 149224 km
Time Indication: 0
Date: 2000.00.00
Time: 00:02:27
Freeze Frame:
Voltage: 11.39 V
Count: 40
02844 - Lamp for Automatic Parking Function
009 - Open or Short to Ground - MIL ON
Freeze Frame:
Fault Status: 11101001
Fault Priority: 4
Fault Frequency: 220
Reset counter: 238
Mileage: 149208 km
Time Indication: 0
Date: 2000.00.00
Time: 18:54:56
Freeze Frame:
Voltage: 12.01 V
Count: 64
Andron2555
Re: PROBLEMA S IMMOBILAIZEROM I PARKOVOCHNIM TORMOZOM
Сообщение pashustic » 31 дек 2013, 18:25
Andron2555 писал(а):Address 25: Immobilizer Labels: 3C0-959-433-25.lbl Part No SW: 3C0 959 433 K HW: 3C0 959 433 K Component: IMMO 038 0367 Revision: 00038000 Serial number: VWZCZ000000000 Shop #: WSC 131071 1023 2097151 Part No: 3C0 905 861 D Component: ELV 024 0370 3C0905861D ELV 024 0370 3 Faults Found:02823 - Requirements for Locking the Steering Column Lock not met 000 - - - Intermittent Freeze Frame: Fault Status: 00110000 Fault Priority: 7 Fault Frequency: 1 Reset counter: 25 Mileage: 150822 km Time Indication: 0 Date: 2000.00.00 Time: 12:31:5502827 - Wake-Up request via ESP 008 - Implausible Signal - Intermittent Freeze Frame: Fault Status: 00101000 Fault Priority: 2 Fault Frequency: 1 Reset counter: 25 Mileage: 150822 km Time Indication: 0 Date: 2000.00.00 Time: 12:31:5502811 - Control Module for Electronic Steering Column Lock (J764) 014 - Defective - Intermittent Freeze Frame: Fault Status: 00101110 Fault Priority: 1 Fault Frequency: 1 Reset counter: 4 Mileage: 149844 km Time Indication: 0 Date: 2000.00.00 Time: 20:31:59
ЗАмена блока ЕЛВ вам светит
Andron2555 писал(а):2 Faults Found:02443 - Control Head 012 - Electrical Fault in Circuit - Intermittent Freeze Frame: Fault Status: 00101100 Fault Priority: 2 Fault Frequency: 1 Reset counter: 252 Mileage: 149224 km Time Indication: 0 Date: 2000.00.00 Time: 00:02:27 Freeze Frame: Voltage: 11.39 V Count: 40
ЗАмена кнопки ручника
Andron2555 писал(а):02844 - Lamp for Automatic Parking Function 009 - Open or Short to Ground - MIL ON Freeze Frame: Fault Status: 11101001 Fault Priority: 4 Fault Frequency: 220 Reset counter: 238 Mileage: 149208 km Time Indication: 0 Date: 2000.00.00 Time: 18:54:56 Freeze Frame: Voltage: 12.01 V Count: 64
AUTOHOLD Установлен ???
Сообщение Andron2555 » 31 дек 2013, 19:31
Da uz, ne dumal, chto nastolko vsjo serjozno... Da, Auto hold ustanovlen. Voobshe knopka parkovochnogo tormoza rabotaet bez vsjakih problem, narekanii voobshe net, no alarm visit i eto, konechno, fakt. Voobshem, kak ja ponjal nuzno gotoviti denezku))
Andron2555
Сообщение pashustic » 31 дек 2013, 20:03
Andron2555 писал(а):Da, Auto hold ustanovlen. Voobshe knopka parkovochnogo tormoza rabotaet bez vsjakih problem, narekanii voobshe net, no alarm visit i eto, konechno, fakt
Лампочка на ней горит при включении... Меняйте кнопку.ВОзможно кнопка тянет парвозом автохолд
Andron2555 писал(а): kak ja ponjal nuzno gotoviti denezku))
ТИп того
ЗЫ можно писать русскими буквами ,а не транслитом! :)
Сообщение SEAT » 31 дек 2013, 20:41
pashustic писал(а): можно писать русскими буквами ,а не транслитом!
можно.если есть кириллица на клаве :D
Сообщение Andron2555 » 04 янв 2014, 11:10
Большое спасибо за ответ. Скинул все ошибки, которые были в памяти. Покатался на машине пару дней, выскочила только одна ошибка: 02844 - Lamp for Automatic Parking Function 009 - Open or Short to Ground - MIL ON. Все остальные ошибки ушли и не повторялись, даже по иммобилайзеру, но печально, что сама проблема с блокировкой руля осталась...
Andron2555
Сейчас этот форум просматривают: нет зарегистрированных пользователей и гости: 38
